Studdering, Kills, Tranny Slips???
Old Dec 8, 2007 | 11:50 PM
Brandon31386's Avatar
Brandon31386 is an unknown quantity at this point
Default Studdering, Kills, Tranny Slips???
I have an issue. Earlier today i took my truck out. Started fine, ran fine, but drove crappy. Felt as if the tranny was slipping(RPM's increase, but no accelleration). Checked the fluid, and its fine. I dont know what is causing it. Then, i took it to my shop where my girlfriend and i replaced the front grill, when i pulled it out of the shop it began to run like crap. It would bogg down, threaten to kill, and not wanna accellerate. I would push on the gas, and it would just bogg.So i shut it off, started it up, and it barely wanted to stay running. I had to pump the gas vigorously in reverse to get it off the main street.
Any ideas on what is causing all this crap? The tranny screwing up, and not it not running? Please HELP! Id appreciate any thoughts and ideas! THANKS!!!!
Old Dec 8, 2007 | 11:57 PM
mdehoogh's Avatar
Default RE: Studdering, Kills, Tranny Slips???
whoops! you missed one... you might want to edit that last line before the Admins get ya
Old Dec 9, 2007 | 08:55 AM
Yeah, we can do with out all of the language.
Anyway, what are you workin' on here? There are 3 different automatic transmissions used in the 1st gen trucks as well as quite a few different engines.
Old Dec 9, 2007 | 06:54 PM
how can i find out that information? I know the engine is a 4.3 ...but the tranny idk.
sorry about the language, i was quite fustrated. I didnt need this to happen before xmas.
Old Dec 10, 2007 | 08:21 PM
southside's Avatar
southside is an unknown quantity at this point
if its a 4.3 then its a 700r4, in my experiance the v6version of the 700r4 have a habit of leaking and failing
southside
Old Dec 10, 2007 | 08:23 PM
mdehoogh's Avatar
ORIGINAL: southside
southside
not necessarily... i have a 4l60e
Old Dec 11, 2007 | 05:42 PM
Hanr3's Avatar
year of the truck will help a bunch.
700R4 until the early '90's.
4L60 until '93.
4L60E '93 on.
In '98 they made it a two piece housing.
Teh internals are basically the same, however the three versions have differences.
No with that said. Crappy engine perforamance will affect trany performance, especially in a late modle truck. Teh puter reads the engine and adjusts the tranny accordingly.
What year is your truck, and verify the engine is a 4.3?
It would also help to know which fuel injection system you have.
My first thought is when was the last time you gave it a tune up?
Old Dec 11, 2007 | 07:03 PM
Its a 1992. 4.3.It has like a carb/TB fuel injection. The last tune up was about 1 year ago. Oil change 1 month ago. I just pulled the truck out of storage about 1 month ago. But whats weird is all day it ran fine except for the tranny slipping....then all the sudden it acts funny, dies, and doesnt wanna start? That leaves me lost because i dont see how the same problem can be related between the two.
Old Dec 12, 2007 | 06:03 PM
southside's Avatar
ORIGINAL: otnietdehoooo
ORIGINAL: southside
southside
i have yet to use a 4l60e but the pre 94 v6 version of the 700r4of which i have had mutiple failures previous to my purchase, with failures caused by a leak in relitly fresh overhauls.
southside
Old Dec 12, 2007 | 08:35 PM
Hanr3's Avatar
'94 would have a 4L60 tranny. Still uses a TV Cable to change gears.
Sounds like your issue is engine related. Wont start!
Storage, how much did you drive. Did you put anything in the gas tank when you put it in storage?
You could have varnish build up clogin up your injector(s). Fuel injection system should be a TBI/TPI.
Pour some ether down the intake and see if the truck will fire and die? If so, everything works except your fuel delivery.
