Stumble at idle.
Stumble at idle.
I have a 1994 S10 blazer w/ a vortec 4.3. It has a new low mileage motor in it, but it has a stumbling issue. It only does it at idle, and it is a random misfire. So far we have changed the cap n rotor, plugs, plug wires, fuel filter. It has also been checked for fuel leaks, and has had the fuel return lines replaced.
What are some places for me to check for a random missfire at idle?
RE: Stumble at idle.
did u check inside the plenum at all for fuel leaks? this could be causing the stumbling and partly cause the misfire. the plastic fuel lines (nut kit), spider injector assembly, or the Fuel Pressure Regulator (FPR) could be bad and causing leaks or improper amounts of fuel inside the plenum.
im having similair problems but mine is an 87 2.8L. try your 02 sensor idle motor control. vacuum lines, EGR valve. pretty much anything in the emissions control system. your best bet is to go to an autoparts store and use their computer scanner. i been trying that with mine but the computer scanners i can get access to dont find any codes.
hope some of this helps.
-Wes-
-Wes-
ORIGINAL: 94blueknight
billfrank85
26
05-29-2012 04:56 PM
blazer chris
12-08-2011 09:56 AM
grendragginbu
01-26-2007 03:04 AM
wolfe1967
08-29-2005 12:27 AM
