surging idle
surging idle
I got my blazer running I thought I had it.right now it has a surging idle and tries to die when you its a 2.8 1988 blazer its throwing a code 34 and 42 any advice on where to start or what could be causing this
Either your timing is off a little bit ( turn distributor to advance a bit ) or you have a vacuum leak. If turning the distributor and checking timing does not solve your issue, then mix up a spray bottle of soapy water and check for a vacuum leak.
UnknownFish
22
11-14-2011 07:40 AM
turquoiseblazer
04-24-2011 10:53 AM
wildboar
05-29-2006 04:35 AM
