Switching from TBI to Carb?
Old Feb 25, 2014 | 03:39 PM
SkyHook's Avatar
SkyHook is on a distinguished road
Default Switching from TBI to Carb?
Is it possible to switch from the TBI setup over to a 2 bbl or 4 bbl carb?
I imagine it would require a different intake but I'm just curious.
Old Feb 25, 2014 | 05:13 PM
Anything is possible. What year, model and engine?
Old Feb 26, 2014 | 12:27 AM
LeWhite's Avatar
Why go backwards? Better to learn your craft!
Old Feb 26, 2014 | 02:06 AM
SkyHook's Avatar
I agree Lewhite, but I still don't like TBI :P
Uhh, '87 S10 Blazer Tahoe with a 2.8l V6
Old Feb 26, 2014 | 01:06 PM
abig84's Avatar
yes. i did it with a 85 2.8.
i bought a 85 that had a engine backfire and burned up the top of the engine. had a donor 83 s10 with a 2.8 and carb on it. i just swapped over the intake carb and distributor. i dont really remember having any problems with it, though i did it back in 2001. also dont forget to change your fuel pump or get a pressure regulator. i turned the key and the carb just became a waterfall of gas
Old Feb 26, 2014 | 10:31 PM
SkyHook's Avatar
Awesome, atleast I know I have that option . I plan on rebuilding this motor come spring so I'm considering swapping it.
Old Feb 27, 2014 | 01:29 PM
abig84's Avatar
from what i remember too with these 2.8s you actually have to pull all the pushrods and lifters off the engine to do the intake. its a goofy set up like the intake kinda goes into the head and the valve cover comes down on both of them. that kinda sucked. but again i did this way back when i knew little about cars and had no problems,
Old Feb 28, 2014 | 08:10 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I believe you are correct. The 2.8, 3.1, and 3.4 are all 60° V6es. The intake gaskets go over and under the pushrods. A special tool is available to lift up the rocker arms to slip the gasket behind it. I've done intakes on 3.1s and 3.4s and love that tool. It saves a bunch of time.
Brandon Smith
Dec 22, 2013 12:33 PM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
lil_blazin
Aug 5, 2009 09:42 PM
dcayers
Apr 12, 2009 01:51 PM
BlazerMan85
Mar 7, 2007 12:21 AM
