T-stat?
Old Apr 27, 2008 | 09:57 PM
Davis's Avatar
Davis is an unknown quantity at this point
Default T-stat?
I have an 87 s10 blazer with a 2.8 and my temp gauge usually sits here (see attached) Do I need a new t-stat? Also my 4wd use to work fine then it started getting tricky on me when I got stuck one time now I dont think it comes on at all (due to the absence of the 4wd light coming on) Is the vacuum actuator easy to get to, and does it look like a normal one? Thanks in advance fellas.
[IMG]local://upfiles/10085/1C871F122DA84B4AB4075F0DB289BC87.jpg[/IMG]
Old Apr 28, 2008 | 06:17 AM
Default RE: T-stat?
A new t-stat is the first thing I would do. While you are at it, check your hoses and replace the radiator cap with a stant safety cap.
Old Apr 28, 2008 | 07:59 AM
rdhack's Avatar
rdhack is an unknown quantity at this point
Default RE: T-stat?
You have two vacuumdevices to look at. One is on the transfer case itself. It tells/pulls suction on an acuator underneath your battery which in turn locked in your front differential.
At least this is the way my 91 Blazer works.
Of course the running a low temperature could affect your vacuum I suspect.
kellysmith
Feb 5, 2009 12:34 PM
MVPalmer271
Jan 31, 2008 08:05 PM
dbleon
Dec 25, 2007 04:04 PM
2klt
Mar 12, 2006 03:57 AM
timetoblaze
Engine & Internal
Feb 18, 2005 04:18 AM
