tailgate wont open
Old Apr 16, 2010 | 06:32 PM
olympia1979's Avatar
olympia1979 is on a distinguished road
Default tailgate wont open
hey guys. my tailgate on my '91 s10 blazer is stuck and wont open. i turn the key for the window and it works great. but the lock wont turn when i want to open the tailgate. how can i fix this problem? thanx for the tips.
Old Apr 17, 2010 | 01:32 AM
old skool luvr's Avatar
you need to remove the screws around the outside of the interior panel. then you.....................
wait, if i remember correctly, you can't get @ the screws, since they're below the seal area. sorry, it's been awhile since i had to remove that panel.
you need to open your rear window, and use a long, slim screw driver (or anything similar) to flip the tab inside to release the latches. it sounds like it might have gotten bent. did you ever have a tough time opening the TG @ any time recently?
Old Apr 17, 2010 | 12:03 PM
the tailgate was working fine. then one day a couple of months back it just didnt want to open up. i didnt think anything of it but know i just want to get it fixed. can you tell me where the tab i need to flip is located? is it hard to find?
Old Apr 18, 2010 | 11:43 PM
ohsofly's Avatar
I broke that handle on mine off so all I have is a keyhole. we slip a screwdriver in the keyhole and turn it. You should be able to get the interior panel off from inside and you will see the bars that go from the key area to each side of the tailgate. Grab onto both of those and pull them toward the keyhole to pop the latches. Then have a look in there to figure out whats unhooked or bent or needs lube.
Thanks for the reminder to fix mine when I have some spare time.
Im working on a 49 desoto latley thats got my attention.
ravenhurst
18
Jan 14, 2017 03:43 PM
MikeTastic
Aug 8, 2012 04:41 PM
chris015
Feb 14, 2012 10:20 AM
coplinb
May 2, 2009 03:10 PM
MoneyPItJimmy
Feb 10, 2008 07:30 PM
