Temp gauge fixed Now for the next problem
Old Dec 30, 2005 | 08:26 PM
92ChevyBlazer's Avatar
92ChevyBlazer is an unknown quantity at this point
Default Temp gauge fixed Now for the next problem
Basically whenever i hit a bump or expansion joint my front end has this loud "thump" to it. If you drive steady all you will hear is the tires singing and the vehicle tracks straight. I already replaced the lower ball joints and the idler arm. What else could cause this?
Old Dec 30, 2005 | 09:02 PM
Default RE: Temp gauge fixed Now for the next problem
Upper balljoints, although it shouldn't be as loud as a lower, a broken swaybar link, possibly a loose or worn shock (but that's stretchin' it). You should also see if your hood hinge bolts are loose. This can cause close to the same sound as a ball joint only up higher.
zakm0n
Jan 9, 2011 07:31 PM
Imperator
Apr 7, 2010 05:05 PM
Malachai
Mar 27, 2010 10:00 PM
trampaslake
Feb 4, 2009 11:24 PM
mboehler
Jan 16, 2009 07:16 AM
