Temperature gauge
Old Jan 7, 2006 | 01:16 PM
Ola Nordmann's Avatar
Ola Nordmann is an unknown quantity at this point
Default Temperature gauge
94 Blazer 4,3
When I turn on the ignition ( with a cold engine ), all the lights on the temperature gauge is lit. ( The high temperature light is flashing )
Is it possible to reset the temperature gauge ?
Old Jan 7, 2006 | 01:25 PM
RedBlaze's Avatar
From: Atlantic, NC (eastside whats crack-a-lackin!)
RedBlaze is an unknown quantity at this point
Default RE: Temperature gauge
Try disconnecting the ground wire from you battery and letting it sit like that for 15 minutes. I know that works for reseting SES codes it might help your problem.
Old Jan 7, 2006 | 01:31 PM
The battery has been disconnected for several days :-)
Old Jan 7, 2006 | 01:41 PM
I was running the engine with a broken generator ( with the heater on max )
After a while all the warning lights start flashing.
After I recharged the battery all the lights stopped flashing, except the high temperature light.
Old Jan 7, 2006 | 02:33 PM
93LT's Avatar
93LT is an unknown quantity at this point
ORIGINAL: Ola Nordmann
94 Blazer 4,3
When you turn on the ignition? What about when the vehicle is running. If you have the digital dash, when you turn the ignition on, all gauge lights light up to show they are working.
Old Jan 7, 2006 | 08:38 PM
Also when it is running ( with a cold engine )
Old Jan 7, 2006 | 09:43 PM
93LT's Avatar
Try disconnecting the temp sensor for the gauge. If you have the Vortec engine, it is the sensor in the right head, single wire. If you gauge reads nothing then, you could try to reseat the sending unit or replace it.
Old Feb 1, 2006 | 06:56 PM
Thanks, it was the temp sensor.
2005Jimmy
Nov 21, 2018 01:33 PM
89GMCJames
Feb 23, 2011 01:08 PM
dobyken
Oct 22, 2010 07:16 AM
ashmarie321
Jul 13, 2010 01:15 AM
redlineracerjpcb
Engine & Internal
Mar 16, 2008 12:35 PM
