Temperature Gauge
Old Feb 23, 2011 | 12:00 PM
89GMCJames's Avatar
89GMCJames is on a distinguished road
Question Temperature Gauge
Ever since I have bought the jimmy, which had 65k on it, the temperature gauge has failed to work properly. There has been a few instances that it did work, but hasn't for a long while. I have recently replaced the Temperature Sender and Thermostat, but neither fixed the problem. Any ideas are appreciated. Thanks.
Old Feb 23, 2011 | 12:07 PM
theonetruetom's Avatar
theonetruetom is on a distinguished road
how's it broken? does it not read at all, does it read low, does it read too high?
Old Feb 23, 2011 | 01:04 PM
89GMCJames's Avatar
It is stuck all the way down. It will not move.
Old Feb 23, 2011 | 01:08 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
if it a one wire sensor then ground the wire, If a two wire then jump the two wires together and the gauge should jump past hot, if it doesnt then you could have an open wire or a bad gauge. if the gauge does jump past hot then you have a bad tempeature sensor.
2005Jimmy
Nov 21, 2018 01:33 PM
dobyken
Oct 22, 2010 07:16 AM
ashmarie321
Jul 13, 2010 01:15 AM
redlineracerjpcb
Engine & Internal
Mar 16, 2008 12:35 PM
Ola Nordmann
Feb 1, 2006 06:56 PM
