temperature gauge
Old Oct 20, 2012 | 05:40 PM
banjomaniac's Avatar
banjomaniac is on a distinguished road
Default temperature gauge
Hi, I have a 94 S10 model 4x4 with the 4.3 Vortec. My Temp gauge in the dash doesn't move, it stays all the way down. My question is whether or not it's the "sending unit", if that's what it's called? The one I'm talking about is on the passenger side of the engine (there is a dipstick tube running real close to/over it). The harnness only to the unit only has one wire to it. Anyways...is there a way to test that temp sending unit or the harness that connects to it with a multimeter? If so what's the procedure? Or am I way off to begin with?
I appreciate all of the help, wisdom, and feedback provided.
Old Oct 20, 2012 | 06:45 PM
jaystoy's Avatar
jaystoy is on a distinguished road
That is indeed the correct sensor. I am not sure how you test it or the sensor, but I replaced mine, was like 15 bucks and restored the guage to proper working order
Old Oct 21, 2012 | 02:15 PM
Pont's Avatar
Pont is on a distinguished road
pull the wire off the sender and have someone sit in the cab. Ground the wire out and if the needle jumps up to max temp then the dash gauge is good and replace your sensor.
Old Oct 21, 2012 | 10:35 PM
Well, it was a bad sensor. New one works great. Thanks for the help guys.
2005Jimmy
Nov 21, 2018 01:33 PM
dobyken
Oct 22, 2010 07:16 AM
ashmarie321
Jul 13, 2010 01:15 AM
redlineracerjpcb
Engine & Internal
Mar 16, 2008 12:35 PM
Ola Nordmann
Feb 1, 2006 06:56 PM
