Throttle Positioning sensor
Old Jul 8, 2009 | 10:58 PM
Baja Blazer 85's Avatar
Baja Blazer 85 is on a distinguished road
Default Throttle Positioning sensor
The check engine light has been lit in my 1985 S10 Blazer (signature). I went and got the codes read and they said TPS (throttle positioning sensor) isn't functioning, and it runs lean.
The check engine light came on right after I got the fuel pump replaced.
I unplugged all of the plugs on the carburator (E2SE Varajet II), blew them out, and plugged them back in. It worked a little but the the check engine light came back on eventually.
Where is the TPS located in the Gen 1 S-Blazer? I looked it up in my Haynes manual and they had limited info on it (only what it was and how it worked, not how to replace it ). How would I go about replacing it?
Now, when I replace the TPS, will it no longer run lean?
Well, thanks alot in advance!
Old Jul 9, 2009 | 08:25 PM
It should be located on a bracket near the throttle linkage.
Check out my reply in the thread linked to below for some information on the E2SE:
carb ?
Here's another one of my replies:
float float float?????
Old Jul 10, 2009 | 01:22 AM
Sweet man thanks!
I replaced it today, it did fix the running rich problem. It no longer smells like gasoline whenever I drive.
Its tricky to figure out what the TPS is/where its located, but the blown up diagram helped alot.
Old Jul 10, 2009 | 10:16 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
what type of gas mileage are you getting now with the carb? i pretty much have the same blazer except mine is the 86 with fuel injection and i was just wondering if its just me getting poor gas mileage.
Old Jul 11, 2009 | 11:57 AM
Fuel injection should give you more mileage
Im getting around 10 - 12
johnnybbik
Sep 13, 2014 07:20 AM
jasonwilde
Mar 24, 2011 07:03 PM
Sorell
Dec 29, 2007 04:29 PM
ivannj
Jan 16, 2007 03:49 PM
tbirr
Engine & Internal
Apr 24, 2006 11:42 PM
