is it time to drop the tank?
Old Nov 18, 2010 | 12:28 PM
gomfrddy's Avatar
gomfrddy is on a distinguished road
Default is it time to drop the tank?
been having an intermitent fuel problem....last time it died the fp relays where real hot and I replaced them....but to no avail.....still no buzzing from the fuel pump and no start.....is ther anything else it could be before I drop the fuel tank?
Old Nov 18, 2010 | 12:31 PM
Pulling the electrical connection at the tank and verify power and ground would be high on my list.
Old Nov 18, 2010 | 12:47 PM
gomfrddy's Avatar
where exactly is that?
Old Nov 18, 2010 | 05:52 PM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
the connector and ground is on the frame rail directly behind the tank before rear bumper. lay on your back and feel along the top of the frame rail, there almost dead center like behind the license plate.
Old Nov 18, 2010 | 10:46 PM
shawncullen's Avatar
shawncullen is on a distinguished road
Wink been there done that
even if the fuel pump is bad
its a easy job no worries
just hope your tank is close to empty
and if you do the fuel pump (round 70 or 80 bucks at advance)
might as well hit the fuel filter as well (10 or 12 bucks advance)
Old Nov 19, 2010 | 06:21 AM
gomfrddy's Avatar
Default Update!!!!
I checked the relay connections and one was not seting right....so the pump buzzes now but te engine won't start....checked spark, got spark....sprayed fuel into the intake and no fire WTF????????
Old Nov 19, 2010 | 06:30 AM
94BlazerPA's Avatar
It wont even run with starting fluid? Just because your pump is buzzing, doesnt mean its working 100%. Pump could be on its last leg.
You need to get a fuel pressure gauge and tell us what pressure your getting at Key ON, not started and if the pressure holds after you turn the key Off.
Old Nov 19, 2010 | 07:05 AM
Ok, what are you working on here? Year? TBI (Vin Z) or CPI (Vin W)? Both have different fuel pressure requirements.
You could have a problem with spark timing or you could have too much fuel caused by a fuel leak inside the engine (if CPI).
Old Nov 19, 2010 | 07:27 AM
godfatheritalio's Avatar
godfatheritalio is on a distinguished road
1986 S10 Blazer 2.8l 4x4
When my fuel pump went my tank and straps were so rusted i put the back seat down and lift up the carpet, and took an air hammer creating a door like rectangle and pulled the pump that way. and when i finished i tac welded the door i created shut i took safe precautions using a fire blanket and all neccessary tools to complete this job.
Old Nov 19, 2010 | 07:51 AM
Ok. Is that TBI or carb'd? I know my old '85 S10 2.8L was carb'd and that was a ROYAL pain to get running correctly.
