is it time to drop the tank?
Old Nov 19, 2010 | 08:42 AM
gomfrddy's Avatar
gomfrddy is on a distinguished road
TBI........where do I check the fuel press?........I am stumped though...cause I sprayed stsrter fluid in the TB and nothing?????
Old Nov 19, 2010 | 09:55 AM
On a TBI motor, you have to put a 'T' adapter in the main fuel line (the larger of the two lines) to then be able to read the pressure.
Is there any fuel being sprayed out of the injectors when you crank it over?
Old Nov 19, 2010 | 11:15 AM
gomfrddy's Avatar
were do you check for that(injectors) and btw is there a place in the motor compartment where i can crank the motor since I am doing this by myself?
Old Nov 19, 2010 | 12:27 PM
Remove the whole air cleaner assembly and watch the injectors while the engine is cranking over. There should be visible fuel flow in a nice uniform spray pattern. No droplets. If there are droplets and/or it is running out of the injectors, then it is flooding the engine.
As far as trying to start the engine from under the hood, I have a little push button that I used to use on older vehicles to wire up to the solenoid on the starter. Haven't used it in a very long time though.
Old Nov 19, 2010 | 12:44 PM
gomfrddy's Avatar
I am sorry I was looking at the book and I have a cpi......disconected the fuel filter.....clicked the ignition and plenty of fuel came out....cause the fact that I sprayed starter fluid in the intake and nothing I am starting to think ignition..o btw I checked the codes no codes
Old Nov 19, 2010 | 01:10 PM
CPI didn't come in until '92 which is well after the last 2.8L found it's way into the s-series blazer.
As I said earlier, you either have an overly rich condition or an ignition problem. I'm just trying to step you through the process of elimination.
Old Nov 20, 2010 | 01:56 PM
gomfrddy's Avatar
I took one of the plugs out and lef it connectd to the plug wire...cranked it and no spark.....will start looking at the dizzie...even though I rebuilt it less than a year ago
teryx750
Sep 25, 2021 08:14 PM
donald_archer
Mar 27, 2015 03:55 PM
rxjimmy
Dec 15, 2014 07:39 PM
jug
16
Oct 24, 2007 12:27 PM
scottyk
Aug 1, 2007 11:47 AM
