Timing setting
Old Aug 26, 2010 | 09:37 AM
maxi52.1's Avatar
maxi52.1 is on a distinguished road
Default Timing setting
I have a 92 s10 Blazer with W engine. I had to pull the dist. When I reinstalled it I could find no info on what to set the timing to. I had to do it by ear. There is no label or info in the engine compartment giving that info like there should be.
Does anyone out there know the the proper setting.
Thank you.
Old Aug 26, 2010 | 07:15 PM
You first have to disconnect the brown timing wire that is off the passenger side of the transmission tunnel at the firewall inside the cab. You can then set the timing with a light to 0* TDC #1
Old Aug 26, 2010 | 07:43 PM
mr.vls's Avatar
Once you set the timing and have reconnected the brown wire you will have a MIL light on. Disconnect the battery for a few minuets and reconnect the battery and the MIL light should be extinguished.
jojocarreno
May 27, 2011 12:27 PM
riddikstraaf
Aug 8, 2010 05:14 PM
A2Zcustomupholstery
Aug 4, 2010 08:07 PM
justin1795
Mar 27, 2009 07:55 PM
nofear17bmx
Jan 16, 2007 12:51 AM
