89 Jimmy F/S 5.7 Setting the timing!!!
Old Jun 23, 2010 | 09:43 PM
A2Zcustomupholstery's Avatar
A2Zcustomupholstery is on a distinguished road
Default 89 Jimmy F/S 5.7 Setting the timing!!!
Can anyone point me in the right direction? I disconnected Tan/black stripe on Driver side firewall and set the timing at 3 degrees to help a little with bigger tires. Specs call for 0 degrees. To get the truck to accelerate it takes a while. Once you reach the desired speed, runs very smooth. Any ideas???Thanks for looking....
Old Jul 29, 2010 | 10:24 PM
bwblazer's Avatar
bwblazer is on a distinguished road
supposed to set to zero
it will adjust itself on veichle speed
Old Aug 4, 2010 | 08:07 PM
Found on the driver side fire wall a plug that has to be disconnected in order to set a 0. Did that and bumped it a little for the bigger tires. Runs like a champ now. Thanks for the help!!!
jojocarreno
May 27, 2011 12:27 PM
maxi52.1
Aug 26, 2010 07:43 PM
riddikstraaf
Aug 8, 2010 05:14 PM
justin1795
Mar 27, 2009 07:55 PM
cbash1979
Apr 9, 2008 05:40 PM
