under dash vacuum lines
Old Jan 3, 2009 | 12:16 AM
quik1964's Avatar
quik1964 is an unknown quantity at this point
Default under dash vacuum lines
Hey gang, do any of you have diagrams etc of the vacuum lines under the dash, and before i go to the extreme pain in the butt of tearing my dash apart i think it may be a good idea to have an idea what to look for, im having heater issues and i definately hear hissing behind the heater controls.
Old Jan 3, 2009 | 08:42 AM
Default RE: under dash vacuum lines
Please, PLEASE put your vehicle information in your signature and attach it to all tech request posts. If you have more than one vehicle, specify in the post what vehicle you are requesting help/information on. The basic vehicle information is required to ensure proper help is rendered.
Old Jan 3, 2009 | 03:59 PM
quik1964's Avatar
Many apologies. My blazer is a 91 4wd 4dr 4.3 tbi
Old Jan 3, 2009 | 07:04 PM
This should help out:
And this gives the logic of how each mode is attained:
Old Jan 4, 2009 | 12:06 AM
quik1964's Avatar
Fantastic! soon as i get it finished i will post results
Old Jan 18, 2009 | 04:56 PM
quik1964's Avatar
kyle those diagrams worked out well. I had to replace my heater core so while i was in there i checked things out, all vac lines i could see were in place. However, I have got mediocre heat at best, do you know if you can "bypass" or shut the fresh air door without peeling the dash out completely? We have had -20 degree weather so heat is vital and money is short so ANY ideas are welcome
Old Jan 18, 2009 | 07:34 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
How well did you bleed the system after you replaced the heater core?
Get the front passenger wheel up higher than the driver's side and run the truck with the rad cap off, adding coolant as necessary. You'll have to let the truck cool completely, then do it again - probably 2 or 3 times.
Old Jan 18, 2009 | 08:16 PM
quik1964's Avatar
i only lost about 1/2 qt antifreeze when i swapped cores and added 3/4 gallon new AF after a couple of running/off cycles.
Could a vent/door from the A/C system be acting up? My family mechanic (son) seems to think that may be a concern. He would look himself but he's in Ohio and I'm in New Hampshire.
schrack
Jan 10, 2015 07:03 AM
pinbill
Dec 22, 2012 09:53 PM
fisherman
Dec 15, 2010 01:28 PM
shootmenow
Sep 26, 2010 09:14 PM
