vaccum for 4x4
Old Dec 20, 2005 | 10:27 PM
BUDWZR8's Avatar
BUDWZR8 is an unknown quantity at this point
Default vaccum for 4x4
I have a 94 s-10 blzr 4x4 and saw a post about 4x4 and vaccum hoses were mentioned. Are there any that could come loose around distributor area where I was working ? Replaced cap, rotor etc. 4x4 does not engage all the way but I can hear it trying to but not the regular sound I normally hear. Could I have unplugged something back there or anywhere else while I was lying across the eng. compartment? Need my 4x4, have STEEP ICEY DRIVEWAY IN CENTRAL IL.!!!!!!!!!!!!!!!!!!!
Old Dec 20, 2005 | 10:31 PM
93LT's Avatar
93LT is an unknown quantity at this point
Default RE: vaccum for 4x4
If it is the Vortec engine then the main vacuum feed is right off the upper right rear corner of the upper intake plenum. One short piece of approx. 1/4" line goes to a vacuum pot that splits 4 ways. My short 1/4" hose was shot as well as the 5/32" hoses running to the vacumm canistor and the Cruise control.
Old Dec 20, 2005 | 10:37 PM
BUDWZR8's Avatar
Thanks alot 93LT I just noticed this trying to get up my drive and you mentioned cruise control and then I remembered on way home from work it did not work, so I thought I would check that out at daylight. So I think ya got it covered!!!!! Ya think??????? THANKS for quick reply.
Old Dec 21, 2005 | 12:18 AM
93LT's Avatar
My leak wasn't enough to bother the differential, but the cruise didn't have enough suction to maintain speed up a grade and my converter would jerk in and out at highway speeds. My guess is your main point of connection is probably not even hooked up.
Old Dec 21, 2005 | 11:14 PM
93LT's Avatar
I got your PM, I tried to return the PM but got the message you couldn;t receive or chose not to receive PMs. I was wanting to know if you had push button or floor shift 4wd.
Old Dec 21, 2005 | 11:31 PM
BUDWZR8's Avatar
push button I put up another post so maybe you can look at that i tried to change my e-mail and prefrecences but it would not work so!!!!!!!
Jimmy Williams
May 3, 2013 08:07 PM
730WATERS
Jan 6, 2011 09:05 AM
Pobey
Nov 4, 2010 11:24 AM
blazer2000ls
Jun 5, 2010 07:31 PM
ron36535
Dec 28, 2005 04:05 PM
