2000 blazer ls 4x4 vaccum problem
Old Jun 4, 2010 | 02:27 PM
blazer2000ls's Avatar
blazer2000ls is on a distinguished road
Exclamation 2000 blazer ls 4x4 vaccum problem
on the driver side under the hood in front of the brake booster there are 3 vaccum lines connected together with a little plastic T piece one goes into the harness into the firewall the other one goes towards the passenger side and the other one is broken off and i have no clue where it connects to. my ac doesnt work well when i accelerate from a red light when i let off the gas it starts working fine. any idea where that vaccum goes????
Old Jun 4, 2010 | 05:21 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Firewall one goes to your heater controls, heading for the passenger side goes to 4WD actuator. The broken one goes to a vacuum reservoir ball inside your drivers side fender. Block the broken T for now (it'll improve things a little) and if you fish through the hole in the inner fender with a wire and hook maybe you can retrieve the rubber hose. They must install that ball before the fender is on the truck.
Old Jun 5, 2010 | 06:20 PM
i plugged it for now but i will just go ahead and take the fender off and find it bc the vaccum that was on it was dry rotted and i replaced them but thank you i will deff get it fixed. o yea and sometimes my front passenger cv axle makes a roaring noise but when i stop at a light and put it from 2 to 4 then back to 2 wheel it will stop but when i take off fast the noise will come back. would that be caused by the broken vaccum also???
Old Jun 5, 2010 | 07:31 PM
RonJon's Avatar
I can see a vacuum leak causing problems in 4WD, but in 2WD no..... It shouldn't be trying to engage the axle. (I'm assuming the noise you hear is a partially engaged axle or one engaging/disengaging with changing vacuum levels). You *may* have a problem with something sticking the front axle vacuum solenoid holding it open. First thing is to fix the vacuum line but you can try this: At the top of the firewall towards the drivers side of center a bit you'll see the solenoid - it has 2 vacuum lines (the line we want goes to the T-fitting you're working with) and an electrical plug with 2 wires plugged into it. Pull off the vacuum line going towards the drivers fender. Plug it with a small screw. See if your noises go away. If they don't reconnect the line and do the button pushing dance to make it go away. (and start a new thread about a new problem)
Jimmy Williams
May 3, 2013 08:07 PM
730WATERS
Jan 6, 2011 09:05 AM
Pobey
Nov 4, 2010 11:24 AM
keithduke65
Feb 22, 2009 11:46 PM
BUDWZR8
Dec 21, 2005 11:31 PM
