vacuum line?
Old Nov 19, 2010 | 11:26 AM
tonyc89jimmy's Avatar
tonyc89jimmy is on a distinguished road
Default vacuum line?
I have a 89 jimmy w/4.3 . my prob is every once in a while when i start it, it starts real ruff and then wont idle unless the brake pedal is pressed down. the master cylinder & booster were replaced, and i cant find the vacuum line. but when it starts up ruff i can hear a loud sucking, by the drivers side of the dashboard. any insight would be appreciated,thanx
Old Nov 19, 2010 | 01:59 PM
Have you tried spraying carb cleaner or unlit propane torch around the intake/vacuum lines to see if the engine noise changes? I have used the propane torch method on many vehicles to find vacuum leaks.
Old Nov 21, 2010 | 07:37 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
ok you have to take your heater controll panel off and on the other side of it there is vacum line harness that clips in on the back of it. it prolly came loose. by heater control panel i mean your controls to change it to heat or A/C or hot or cold and what not. it happended to me but coulnd not find out what it was for a long time.
Old Nov 27, 2010 | 10:25 PM
thanx for the advise
i put the newer dash in and didnt totally hook up the back of the heat controls. never thought that would do that
Last edited by swartlkk; Nov 28, 2010 at 08:40 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 28, 2010 | 10:23 PM
bam_9_9_9's Avatar
glad to help
Old Nov 28, 2010 | 10:33 PM
STARMAN's Avatar
STARMAN is on a distinguished road
bruce_w
Oct 27, 2024 04:16 PM
Bberry20
Oct 27, 2009 02:44 PM
tesshin
Apr 28, 2007 03:12 PM
dusted800
Nov 17, 2006 06:32 PM
1996BZR
Jun 2, 2006 08:56 PM
