General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Vacuum line?
Old Nov 17, 2006 | 12:07 PM
dusted800's Avatar
dusted800 is an unknown quantity at this point
Default Vacuum line?
I am still having trouble with my 4wd. I found a rubber line 7/32 that comes out above the brake booster on my 95 blazer. The other end is attached to the black plastic ball that is mounted to the underside of my hood. The problem is I don't know where this is suppose to attach to. It heads toward the back of the engine. Can anyone help me with this? thanx. wnk.
Old Nov 17, 2006 | 01:09 PM
Chevy Lover's Avatar
Default RE: Vacuum line?
It probably heads towards a plastic vacuum tee on the passenger side of the transfer case.
There is a vacuum switch on the upper right side of the transfer case that is fed by that vacuum hose....I believe.
Old Nov 17, 2006 | 01:41 PM
dusted800's Avatar
This line does not have any vacuum when I start the vehicle. I am assuming that it must plug into some sort of vacuum source?
Old Nov 17, 2006 | 06:32 PM
mellon101's Avatar
mellon101 is an unknown quantity at this point
I do not know exactly what you are driving ....but on my 96 if you follow the hose from the PCV to it's source, the source for the hose you are talking about is directly below it.
bruce_w
Oct 27, 2024 04:16 PM
Bberry20
Oct 27, 2009 02:44 PM
kakn
Jul 22, 2007 09:14 AM
tesshin
Apr 28, 2007 03:12 PM
1996BZR
Jun 2, 2006 08:56 PM
