Want to bypass heater
I want to put shut offs in my heater hoses to kill all the heat to the core. I'm in Texas and the a/c blows really warm for about 30 seconds when I start the car. I don't need the heat for MOST of the year, and want to know if I need to put in a by-pas under the hood, or is it safe to just shut the lines off? It's a 1994 s-10 4dr, Tahoe with the W engine.
Thanks,
Pete in Texas
Thanks,
Pete in Texas
You just get a 5/8 hose connector, and take the 2 ends off the heater core and join them together with the connector you bought. Done. No heat.
And after you are done, you will realize that everything that you just changed didn't have any really noticeable impact on the problem...
The reason why it blows hot for a bit after it has sat out in the sun is because all of the ducts are hot. It takes a bit for the ducts to cool down and as they do, they are heating up the air that is going through them. Not having hot coolant running through the heater core may reduce the heat soak aspect a bit, but it won't solve the problem.
Pete in Texas
It sound like its just pushing the air around the cab, even though you disconnected the heater core you still with have the stale air in the cab. Check your out side cab to the blower motor and make sure it is cleaned out and nothing is blocking it. Some very few models of your truck also had Cabin Air filters check to see if you have one and replace it or just put a screen in its place.
Pete in Texas
Install a remote starter on your truck, leave the AC turned ON, and just start your truck when your about 40 secs away, by the time you get to the truck that 30 secs of hot air should be gone and your AC should be blowing nice cold air for you.
I guess the main question I have is does coolant need to flow through the heater lines, or can they e stopped by a shut off. I don't know if there needs to be some flow through them. My ac is fully charged and I was thinking that there is some warmth coming into the system while the A/C is on that is reducing the cooling power.
Pete in Texas
Pete in Texas
No you can loop the heater hoses. Lots ofpoeple do that when the core starts leaking. Dont block the hoses, just join them together.
gomfrddy
09-03-2011 05:44 PM
tilleyvideo
08-05-2009 08:10 PM
krystle
06-28-2009 08:56 AM
