Washer Issues
My washer fluid is messed up!
Both front and rear wipers work but the washer switches work the wrong one!
The front switch works the rear washer, the rear switch works the front washer.
Can anyone figure this out? I even looked at the motors and appear different enough that they couldn't be switched. Fluid is full, wipers work, just the switches seem to be backwards.
Help
1993 Chevy Blazer
4x4
350
Help
1993 Chevy Blazer
4x4
350
Just switch the pumps that go into the washer fluid reservoir. It's really easy to do, they should just pull right out of the reservoir. Just make sure you are out of fluid when you do this, otherwise it will all just leak out of the holes.
racechaplain
14
May 13, 2014 05:42 PM
corvetteman
Jan 31, 2010 04:27 PM
xAnarChisTx
Jan 8, 2010 08:04 PM
