What is the name of it and how do i fix it?
Old Dec 31, 2010 | 03:34 PM
tony991's Avatar
tony991 is on a distinguished road
Default What is the name of it and how do i fix it?
There is oil leaking from under the engine of my 1988 s-10 blazer. It's coming from where the two oil lines from the filter enter the engine. What's it called? Is there a gasket that usally leaks there? I have a picture attached...
Attached Thumbnails What is the name of it and how do i fix it?-102_1958.jpg
Old Dec 31, 2010 | 04:02 PM
AJBert's Avatar
This is the oil line itself, which is common to leak at the crimps:
http://shop.synergyoffroad.com/Chevy...nes-625001.htm
Though, yours does look like the fitting to the block is leaking. I would give the dealership a call about a gasket or o-ring.
Old Dec 31, 2010 | 05:57 PM
Blazin_Jason's Avatar
HELP!/Dorman part number 82560. You're welcome.
Old Dec 31, 2010 | 08:44 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
I put the Dorman parts on mine and they leaked. There is a couple of gaskets and a bunch of "O" rings that are just about the same size but slightly different. I bought the right ones from the dealer and they fit great and no leaks. A couple of bucks more but you get the correct gasket and "O" ring for the job. The oil line seals should be changed at the same time and they're not cheap. This isn't a real easy job to do. That center bolt on the line fitting is best tacklrd with about a 18" extensionfrom the front of the engine. If you can get away with jusr the gasket and "O" ring you're much better off. By the way this is an oil filter adapter for the remote filter. Good luck. A lot of guys modify the lines to steel braided hoses when they have theirs out. Wish I would have. But my lines were leaking as well as the gasket/"O" ring.
Old Dec 31, 2010 | 11:12 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Felpro makes a kit that can be found at Napa. This is the kit I used when mine started leaking and haven't seen a drop of oil in my driveway since. I replaced my oil lines with a set made by dorman and they are holding up great after 2 1/2 years of service.
r_marczak_83
17
Mar 9, 2013 10:33 AM
Blazerbomber96
Nov 2, 2012 08:13 AM
mowermechanic
Nov 28, 2011 11:30 PM
serenity12723
Mar 9, 2011 04:47 PM
Dodge Guy
Oct 25, 2006 08:48 AM
