Why Compare Timing Gears BEFORE Installing
Old Oct 26, 2011 | 10:13 PM
Chzyrider's Avatar
Chzyrider is on a distinguished road
Default Why Compare Timing Gears BEFORE Installing
I was replacing the timing chain/gear set in my son's 1992 S10 Blazer 4x4, ordering the Cloyes set from an online source with the gaskets. In comparing the two sets laying flat on the table, they appeared to be correct. Anyone would not normally notice any abnormal differences and install the new set. But through my experience with the occasional mis-labled or mis-boxed part, I always compare the gears over each other to confirm the chain link count, tooth count & diameters.
However in this case, when I slid both of the bottom drive gears (loosely) back onto the crankshaft, that's when things did not match up. It has apparently been mis-machined and the teeth did not align with the old gear as seen in the photo. The replacement gear was off a couple degrees or so.
I called the online source and sent them the photos. They were very grateful in letting them know of this defect and said they would try to check their existing stock for others and promtly refunded my money.
I purchased another set from my local parts store and compared the two on the crank and they matched exactly. Both sets had the S-511 stamped on the bottom gear, but the one gear must've been machined on a Monday morning. So always double-check your parts!!
Old Oct 27, 2011 | 09:22 AM
JustJerry's Avatar
JustJerry is on a distinguished road
Wow! I would suspect many would have just put it on unaware until they tried to start their engine. It pays to check everything every time.
wierdo124
Jul 21, 2013 09:52 PM
James1965
Jan 16, 2012 11:32 AM
pinktruck
Aug 14, 2007 01:27 PM
Blaze1forU
Tires and Wheels
Mar 24, 2007 07:18 PM
97blz4x4
Jan 22, 2007 04:16 PM
