2000 blazer help and info....
Old Feb 21, 2010 | 09:13 PM
bustedazzblazer00's Avatar
bustedazzblazer00 is on a distinguished road
Default 2000 blazer help and info....
so im new to the chevy world,i bought a 2000 blazer 4.3liter 4x4 with a 2001 extreme engine in it, now the problem im havin is the check engine lite is on because of the knock sensor, now i really dont want to have to pull the motor to tap the block to get the knock sensor to fit and clear the code what is a alternative? can i use the old 2 wire knock sensor from the 2001 motor and some how trick the computer to think its a 1 wire? or does anyone hardware store sell some kind of reducer that i can use the new knock sensor and a reducer to get it to work.....HELP PLEASE
Old Feb 22, 2010 | 06:56 AM
Are you sure your block is not machined correctly already? There are two knock sensors shown for the '01 so you could have either the bolt on or the thread in.
As far as the sensor goes, I would have to look at a wiring diagram to be sure, but I would bet that the two wire sensor is just a ground and sensor output. I do not believe it really matters which is which due to the way a knock sensor works, but again, I would have to verify that by looking at the wiring diagram.
Old Feb 22, 2010 | 09:05 AM
thanks and please let me know....
Old Feb 22, 2010 | 05:11 PM
The wiring diagram for the two wire sensor shows both wires going back to the PCM. After reading up on them, it would not appear that they are compatible.
Here is a little run down on the two different knock sensors:
Purpose:
The knock sensor (KS) system enables the Powertrain Control Module (PCM) to control the ignition timing advance for the pest possible performance while protecting the engine from potentially damaging levels of detonation. the sensors in the KS system are used by the PCM as microphones to listen for abnormal engine noise that may indicate pre-ignition/detonation.
Sensor Description:
There are 2 types of KS currently being used:
  • The broadband single wire sensor
  • The flat response two wire sensor
Both sensors use piezoelectric crystal technology to produce and send signals to the PCM. The amplitude and frequency of this signal will vary constantly depending on the vibration level within the engine. Flat response and broadband KS signals are processed differently by the PCM. The major differences are outlined below:
  • All broadband sensors use a single wire circuit. Some types of controllers will output a bias voltage on the KS signal wire. The bias voltage creates a voltage drop the PCM monitors and uses to help diagnose KS faults. The KS noise signal rides along this bias voltage, and due to the constantly fluctuating frequency and amplitude of the signal, will always be outside the bias voltage parameters. Another way to use the KS signals is for the PCM to learn the average normal noise output from the KS. The PCM uses this noise channel, and KS signal that rides along the noise channel, in much the same way as the bias voltage type does. BOth systems will constantly monitor the KS system for a signal that is not present or falls within the noise channel.
  • The flat response KS uses a two-wire circuit. The KS signal rides within a noise channel which is learned and output by the PCM. This noise channel is based upon the normal noise input from the KS and is known as background noise. As engine speed and load change, the noise channel upper and lower parameters will change to accommodate the KS signal, keeping the signal within the channel. If there is a knock, the signal will range outside the noise channel and the PCM will reduce spark advance until the knock is reduced. These sensors are monitored in much the same way as the broadband sensors, except that an abnormal signal will stay outside of the noise channel or will not be present.
KS diagnostics can be calibrated to detect faults with the KS diagnostic inside the PCM, the KS wiring, the sensor output, or constant knocking from an outside influence such as a loose or damaged component. In order to determine which cylinders are knocking, the PCM uses KS signal information when the cylinders are near Top Dead Center (TDC) of the firing stroke
Old Feb 22, 2010 | 07:54 PM
thanks for the info
krazii
Jul 27, 2011 12:51 PM
serrasalmus
Feb 20, 2011 11:20 PM
2000blazerdudeman
Feb 24, 2010 06:22 AM
Punish3rx50
Jan 31, 2009 10:37 PM
MBremer
Oct 2, 2006 10:59 AM
