2000 blazer trouble codes
we have a 2000 blazer ls with 136000 miles
it has given me codes today of
p0300
p507
p1133
p1153
p1380
p301
and chassis codes
c0226
c0225
c0221
c0223
c0387
We just got this blazer for the wife no rust and new transfer case very nice truck just need to fix these problems we sold our ford explorer to buy the Blazer... Thanks for the help
p0300
p507
p1133
p1153
p1380
p301
and chassis codes
c0226
c0225
c0221
c0223
c0387
Here's a starting point in identifying trouble codes. https://blazerforum.com/forum/diagno...codes-dtcs-49/
When a DTC, (Diagnostic Trouble Code) sets in memory, additional DTC's may be set after it, and they may or may not actually be a problem. When troubleshooting DTC's, the first one set must be diagnosed, repaired, and a General Motors Driving Cycle must be performed to confirm the repair.
When multiple DTC's are set, write them down in the order they are retrieved. Then clear all of the memories: pending, current and history. Entry level scan tools, (those less than ~$1500) will not access the history files. After memories are cleared, perform the General Motors Driving Cycle and retrieve the DTC's. Then diagnose and repair the first one retrieved, and repeat the drive cycle to confirm the repair. Repeat the process until no DTC's are present after the drive cycle is performed.
Keep in mind that disconnecting the battery does NOT clear DTC's in the history file. It will turn the check engine light off, unless there is a hard fault present, in which case, it will come right back on.
The drive cycle instructions for each step must be followed exactly as written. Each step must be performed, but the steps do not need to be performed in order.
The first 4 codes for the chassis is for the front abs signals missing and the last one is the transfer case failed to shift. Failing to shift could be caused by several things.
Yep, what the captain said!!
abadinalbany
04-16-2011 11:31 AM
chevycrazy2011
02-22-2011 04:05 PM
