2001 Blazer 4wd Fuel Pump Issue
Old Mar 27, 2012 | 06:42 AM
nj4x4blaze's Avatar
Default 2001 Blazer 4wd Fuel Pump Issue
July 2011 my fuel pump died so I had it replaced. Sadly I went with a Airtex unit which was a mistake. That lasted for 3 weeks and crapped out. The pump would kick on every other day or three days. Finally at the end of august it wouldn't fire up anymore. I gave up and left in the garage throughout winter.
Feb. 2012
Replaced fuel pump with a brand new Delphi Unit and new Battery. Truck fired right up like nothing ever happened. Since then I've been driving the truck 3 times a week since it's not my daily driver anymore.
Yesterday I get home from work and went to take the truck out for a drive and nothing. Truck will crank but no noise from the fuel pump. I removed the wires from the pump and used a test light to see if the pump is getting power. I had my wife turn the key to run and both the black and black/white wire get power.
Would anybody have any idea what else could cause the pump not to turn on? I'm going to pick up a fuel pump relay today after work to see if that's a cause even tho the pump is getting power.
Old Mar 27, 2012 | 07:33 AM
pettyfog's Avatar
Originally Posted by nj4x4blaze
.... I removed the wires from the pump and used a test light to see if the pump is getting power. I had my wife turn the key to run and both the black and black/white wire get power.
Except the black {fuel pump}and black/white {gauge gnd ref} are grounds... or supposed to be. So exactly what did you probe and what were the readings.. and what does your fuel gauge read?
Gray is fuel pump power + during the 2 second prime
If the black is positive referenced to the black/white, then trace through splice pack 423 to the grd point atop the crossmember over the differential.
Old Mar 27, 2012 | 11:47 AM
50lb_cat's Avatar
Did you check the fuse by any chance? I always look at the easy solutions first then start workin my way up lol.
Old Mar 27, 2012 | 01:53 PM
nj4x4blaze's Avatar
I could be wrong on the color of the wire. It was dark in my garage. I used a test light just to see if I'm getting power. And my fuel gauge reads that I have half a tank of gas left. I'll double check the color of the darker wire when I get home.
Old Mar 28, 2012 | 08:09 AM
nj4x4blaze's Avatar
I looked last night and was black and the grey wire that got power when I turned the key to the the run position. They would power up for a few seconds which I assume is enough to prime the pump. I replaced the fuel pump relay last night and still no luck.
Old Mar 28, 2012 | 05:24 PM
You've got power and ground at the pump. Which connector do you have at the fuel pump module?
Old Mar 30, 2012 | 06:29 AM
nj4x4blaze's Avatar
The new connector
Old Mar 30, 2012 | 07:11 AM
pettyfog's Avatar
OHM to chassis {gnd} from the FP prime socket. single slot next to the fuel pump relay
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
Dacor
Dec 3, 2008 10:10 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
