95 S10 Blazer Service engine soon light on, no codes
Old 02-16-2010, 05:24 PM
chuck5104's Avatar
chuck5104 is on a distinguished road
Default 95 S10 Blazer Service engine soon light on, no codes
I'm trying to figure out this 95 Blazer I bought. It sat for 5 years and the gas tank was bone dry when I got it. I put a couple gallons in and it started right up. I drove it to the gas station and put in 3/4 of a tank, and drove it about 30 miles that day with no issues.
The next day I took it for a drive and noticed that it was extremely spongy with no power, so I drove it back home so as not to get stranded. The next day (yesterday) it would not start at all. Today it fired right up again but it was exhibiting the same spongy symptom and the service engine soon light was on. I hooked up my OBDII scan tool and it's acting like it is linking up alright, but when it reads it retrieves no codes. I checked my service manual for the procedure to check codes on an OBDI system and I do not have the proper pins in my connector so I'm fairly certain that it is an OBDII compliant system. Is it even possible to have a service engine light on with no stored codes? Could the scan tool be the issue here?
I was curious if the 3/4 of a tank of gas I put in could have stirred up deposits in the tank that clogged my fuel filter, causing the driveability issues. Any Ideas?
Old 02-16-2010, 05:25 PM
1998ZR2's Avatar
1998ZR2 is on a distinguished road
you could have a spark plug wire arching.
Old 02-16-2010, 06:17 PM
If the CEL is on, there are stored codes. There are actually three different ECM configurations for this year. Sounds like yours isn't fully OBD2 nor fully OBD1, but the mongrel OBD1.5 setup. You need a scan tool that is capable of reading your system.
Old 02-16-2010, 06:18 PM
chuck5104's Avatar
Would that cause a Service Engine light with no codes to retrieve?
Old 02-16-2010, 06:22 PM
chuck5104's Avatar
Is there a definitive way of checking to see which system my truck is equipped with? If it is the OBD 1.5 setup, can you point me in the direction of the proper scan tool? Glad I borrowed this one from a buddy instead of buying one right away (even though I should probably have one for the garage anyway)!
Old 02-16-2010, 06:24 PM
Search around. Both questions have been asked and answered.
Old 02-16-2010, 06:38 PM
chuck5104's Avatar
Fully OBD2 - OBD2 connector under the dash on the driver side with the PCM located under the hood on the passenger side. Only late model year 95's got this configuration, but again, I have not been able to find any change over information.
I pulled this quote from another thread. This is the setup I have. Connector under dash, to the left of the steering column. The PCM under the hood, mounted to the coolant reservoir. This vehicle was in a front end collision before I bought it, so no sticker with OBD2 proclamation. The scan tool is an Innovia 3100. The occupied slots in my diagnostic connector are : 2,4,5,9,13, and 16. This should positively identify my vehicle as fully OBD2 compliant, correct?
Old 02-16-2010, 06:39 PM
1998ZR2's Avatar
you could disconnect the battery and reset the computer and see if the light comes on again and then try the OBD2 reader. an arching plug wire could explain the surging.
Old 02-16-2010, 06:46 PM
chuck5104's Avatar
Tried the negative battery cable reset and the light comes on again. I still cannot retrieve codes. I even read the scan tool instructions!
Old 02-16-2010, 06:49 PM
1998ZR2's Avatar
maybe try another scanner?
Quick Reply: 95 S10 Blazer Service engine soon light on, no codes
