Diagnose this slime?
Old 12-21-2018, 05:41 PM
Mike.308's Avatar
I definitely cannot share Your experience with a loose CV boots nor issues with repaired brake calipers.Call me a lucky guy
As for Your question, grab the boot with a hand and give it a squeeze. You should feel the grease inside. That would tell You whether it has emptied or not. The boots are not fully stuffed - You may compare with the boot on the opposite side. Maybe it's just a clamp then?
In regards to the rubber suspension components - I have been playing a bit with casting the polyurethane parts for my own project (not automotive though). I went across different sets and I can say Axson F38 seem an excellent material for these. It has a pot time of a few minutes (literally You see it curing). Hardens to 70-72 shore D in 72hrs, and is not prone to cracking. If I ever had to replace something, I will take the measurements, 3D print the molding form and enjoy my self-made parts. I expect they should be even better than genuine (polyurethane seems to be the best material for suspension liners). This is going to be my method instead of waiting the delivery time to Poland.
  #22
Old 12-21-2018, 05:53 PM
odat's Avatar
odat is on a distinguished road
Originally Posted by RedBlezer
i dont know what the missing rubber is supposed to look like. I see the two rubber bushings holding the strut to the mount, via the bolt. Where is the missing rubber supposed to be? I dont have any clunking or rattling, especially going over bumps
Sorry I hadn't expanded photo and the bolt holding prob a brake line in the top of the bracket made the shock look like the other style of shock with a center attachment stem - MY BAD LOL
  #23
Old 12-21-2018, 06:16 PM
Mike.308's Avatar
If the boot seems to be OK I've decided to take another look to the posted picture. I've circled yellow something that looks like a torn.
The green line separates clean surface from the messy part. Another option may be the leaking axle seal and the matter we see is the mix of water and oil. You may check the diff oil level.
  #24
Old 12-23-2018, 09:09 AM
Sorry but I didn't keep any parts when I did my lift back in april. I didnt even think about posting them up on here to get rid off...
  #25
Old 01-18-2019, 12:55 PM
RedBlezer's Avatar
RedBlezer is on a distinguished road
i didnt even see that crack, but will check the diff fluid due to the direction of spray.. agree it looks like oil mixed w water/dirt.
  #26
Old 01-18-2019, 03:49 PM
christine_208 will become famous soon enough
When I had a leak of differential fluid it was consisted mostly of clean oil that actually acted to clean up the dirt on the lower control arm. When my inner CV boot slipped off, it looked like dark ball joint grease was splattered everywhere.
If the inner joint is ok with no wear and only in need of more grease, I would recommend replacing the boot. With a $10 tool from NAPA. it is easy to install the correct bands. To disassemble and reassemble the joint only requires snap-ring pliers. The hard/annoying part is having to remove the drive axle first. The kit I used for the boot was from NAPA. It came with a new neoprene boot (i.e more flexible), grease and the two bands you need to clamp the boot in place. I'll be replacing the inner boot on the other side in the spring.
  #27
Old 01-18-2019, 04:57 PM
RedBlezer's Avatar
thanks for all that info, big help!
LannyL81
02-15-2015 08:43 PM
LannyL81
09-04-2011 04:28 PM
porkfriedrice
04-02-2011 11:07 PM
tony991
17
05-06-2010 01:05 PM
fondo
07-22-2009 05:22 PM
Quick Reply: Diagnose this slime?
