Early Signs?
Old 10-06-2008, 12:00 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Default Early Signs?
This weekend I was out with some buddies, and I put down my driverside window, but when I went to put it back up the didnt do anything. I tried a minute later and it went back up. Then I put it down to see if it just got stuck or something and it did the same darn thing. So I was wondering if its early signs of the window motor going dead or the switch on the driverside doorpanel?
Old 10-06-2008, 12:04 PM
Default RE: Early Signs?
I would say that the window motor is probably on its way out. Could be a track alignment problem, but...
Old 10-06-2008, 12:23 PM
punxweb's Avatar
punxweb is an unknown quantity at this point
I had the same issue, occasionaly the window would not go up. I replaced the motor and all has been well for a year and a half.
Old 10-06-2008, 12:30 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
Mine does this about twice a month. ALL I have to do, is pry up the window switch panel on the door(pry from the front, and it should lift right up - the whole switch panel). I guess wiggling the wire going into the switch, is enough to make mine go up, everytime so far.
Monica Williams
11-27-2014 03:10 PM
dannyb91979
07-16-2013 06:08 PM
Blazergirl98
03-25-2012 08:31 AM
Klturi421
20
12-14-2011 10:13 AM
big armo
06-23-2011 09:33 PM
Quick Reply: Early Signs?
