EVAP System CEL
Old 10-27-2008, 06:55 PM
hebelracing38's Avatar
hebelracing38 is an unknown quantity at this point
Default EVAP System CEL
Speaking of EVAP problems, I have a 98 Blazer, I have a EVAP CEL problem, dealership told me that I need new sending unit, but I noticed that the silver tab, just under the fuel cap, does not close anymore. Could this be my problem, instead of the sending unit.
Old 10-27-2008, 07:04 PM
Default RE: EVAP System CEL
What is the code that is popping up? Do you know what tests the dealership performed to determine that the sending unit was at fault?
Old 11-01-2008, 05:18 PM
P0442 was the code I believe it to be, and they said they use some "detector" around the gas tank, and the sending unit is what they believed it to be. I have yet to go back to them, during the same trip the ripped my door handle out of my vehicle while taking itoff the lift. Anyways, I'm just trying to cover all my bases before I go and drop the gas tank. Also, wen I bought it, it had a locking gas cap, which I have read on other forums, might cause this codr, went out, bought a new one, reset the computer, and was fine for awhile, but then came back on.
Old 11-02-2008, 04:13 PM
I still find it difficult to believe that the sending unit is at fault, but if they used a smoke machine on it, they should have found the source... Check out the DIY section for the diagnostic chart for this code.
PaulS 1960
07-26-2011 10:05 PM
Wayner1011
02-16-2011 10:03 AM
Matt Krogman
10-04-2010 11:26 AM
Indianarocker
05-18-2009 04:42 PM
turretman
01-21-2009 06:19 AM
Quick Reply: EVAP System CEL
