Are Exhaust SLEEVE CLAMPS (x2) RIGID enough to support CAT without exhaust hangars?
2002 Blazer 4WD
I'm trying to replace the CAT using just exhaust sleeve clamps, no welding. I may need to take it apart again is one reason I'm not welding.
The diagram shows fairly well what I'm attempting to do.
There is nowhere to add an exhaust support hanger in the span between the headers and the CAT, about a 5' or 6' span (guessing). So that means the entire span weight is supported by the 2 sleeve clamps. The exhaust hanger is after the CAT toward the muffler.
It seems like that would put a lot of bending stress on the exhaust line, with every off-road bump flexing the sleeve clamps more, bending the line and stressing the exhaust headers. Seems like it would torque on the headers, similar to if the exhaust was just cut off and hanging a few feet back from the headers (but less).
Does anyone have any experience or recommendation with this kind of situation?
The other option would be adding some kind of support under the exhaust line where it crosses over the support that holds the transmission, but that doesn't seem like a good idea for some reason, like it might jar the exhaust line somehow.
Thanks!
Thanks!
It should be fine using clamps as long as you plan to use an exhaust pipe expander to sleeve each joint securely into the next. the longer the inserted section is the more rigid your connection will be.
I use a pipe sleeve clamp to link two severed lengths of 2" pipe. It was meant to be temporary but has held up for a long time now. Got it at Autozone for like 5 bucks, has one screw for tightening, kind of like this
That clamp held up to a butt joint (no pipe overlap), and you don't have any noise/leaks? that's a pretty neat take on fastening a sleeve clamp with the hook like that.
If it ever loosens, these Sleeve Clamps are only about $8 and do a real nice job of keeping a tight joint. There is one for lap joint (overlap), and a different one for butt joint. (pic)
I have this type of clamp on another vehicle. It does a fairly good job of sealing 2 pipes (butt joint). But it has a problem if there is an rotational weight. It tends to rotate a bit over time. Not sure how it will work on the Blazer.
Thanks! I was considering wrapping a few layers of tin foil between sleeve and pipe to tighten things up if needed.
luvit
03-30-2012 07:39 PM
chipjumper
06-17-2010 12:24 PM
