floor trim
Old 10-11-2007, 02:27 PM
rjskriba's Avatar
rjskriba is an unknown quantity at this point
Default floor trim
I need some help. I need take the trim off the floor along the door bottom so i cam pick up the carpetI don't see amy screwsor are they hidden? it is a 95 4door 4 x4 Ineed to run a wire under the carpet to the back of the front seat so any help as how to take the trim would be appreciated thanks
Old 10-11-2007, 02:42 PM
Default RE: floor trim
Just pops up. It has spring clips on it. Start at one end with a screw driver and work your way to the other end.
Old 10-11-2007, 03:13 PM
rjskriba's Avatar
thanks for the info,I was going to try that but I didn't want to break it
Old 10-11-2007, 03:17 PM
No problem! The metal spring clips may like to stay in the slots on the floor board. If this happens, just pry them out with a screw driver and push them back onto the tabs on the trim peice before you reinstall the peice or it won't fit right.
Old Skool Soldier
05-03-2012 01:17 PM
awhoff
05-23-2006 01:56 AM
SKIN
Detailing
05-12-2006 12:08 AM
blazerscooby
02-19-2006 01:16 PM
Chevy31104
03-15-2005 12:10 AM
Quick Reply: floor trim
