Front differential click
Click coming from the front
only happens in 4x4 or 4auto
its a 2005 with an automatic
doesnt happen in 2wd. The light stays on so I am assuming the 4x4 is working but I’m scared to really test it. Research is leading me to believe it’s the carrier bearing? Any way I can test or confirm before ripping the half shaft out?
words of wisdom appreciated. I’m in a pinch.
There's a tech article that covers the more common occurrence of this where it clicks in 2wd, but not in 4HI/Auto4wd and it likely is the same problem; a sticking or worn engagement collar inside the front axle. It could also be a sticking engagement cable as well. The tech article shows you what's in there and how to diagnose the issue.
