Fuel tank pressure sensor 2000 Blazer 4Dr
I want to replace the fuel tank pressure sensor on my 2000 Blazer 4Dr but can't locate. Have checked gas tank but can't but am having difficulty seeing the top of the tank for possible location. A precise location to look would be a blessing.
This is not the fuel pressure sensor, it's a sensor that monitors fuel tank vacuum pressure
Last edited by 3D_Illustrator; 04-24-2013 at 01:12 PM. Reason: confusion with fuel pressure sensor
![Fuel tank pressure sensor 2000 Blazer 4Dr-img_20130424_091619%5B1%5D.jpg](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/14253d1482430216t-fuel-tank-pressure-sensor-2000-blazer-4dr-img_20130424_091619%5B1%5D.jpg)
HTH, Don
The four wire connector on the pump module is for the Fuel Pump and Sender, the other three wire connector is for the pressure sensor.
The Pressure sensor is clipped to the top of the module and can be replaced without removing module from tank, but you will probably have to lower the tank a couple inches or so to replace it.
fattracker
02-20-2013 04:21 PM
dj00140
06-16-2011 12:38 PM
okiedoak20
13
07-30-2010 07:39 AM
Spartan66
07-11-2008 02:34 PM
goat6500
02-03-2007 01:28 PM
