hard to start, rpm jumps and feels like running out of gas
It is quite common for the fuel pumps to be a problem and Captain Hook knows his stuff. In fact, since I doubt you took the time to even read the posted link, Captain wrote it. Following the tests will rule out needlessly changing the fuel filter. Like I said, if one is going to crawl around under a Blazer to swap out a fuel filter, you may as well test the pump while you are down there.
There is a lot of great information on this site from some very knowledgable people. I'm certainly not trying to be rude to you as a new member, however, your advice so far has been less than helpful to anyone... Maybe stick around and learn a little more before suggesting the guess and check method...
overheating issues....
Ok I have another problem again with this blazer and if I can get I running in selling it! I can't take this anymore. I was driving home from work and first I noticed my heat wasn't warm, then I notice my blazer was starting to get hot. So I pull off and I can clearly see antifreeze in the tank. So I was almost home and I shut it off let it cool and got it home. So I did the cheapest thing and replaced thermostat, but still overheated. I check the radiator and there was no coolant at all in there but the tank was full. So filled radiator with antifreeze let it circulate thru and it still overheated. I did notice while it was running and when I was waiting on it to circulate there was bubbling in the tank with the antifreeze that was already in it. I haven't noticed any leaks or spots under it since I filled radiator. What could be the problem, water pump?? I'm so frustrated with this blazer, its been sitting broken down more then I have driven it and its causing me to miss work. I need to get it fixed BC I'm selling it as soon as I can get the temp. Correct to sell it. Please help???
Markolc
06-11-2012 08:13 PM
Jefro2010
06-03-2011 07:08 PM
FlatTopFoley
11-24-2009 08:00 PM
jigalow43
06-13-2007 08:55 PM
