Heat/AC Issue
Old 11-24-2008, 10:41 AM
Blazin1's Avatar
Blazin1 is an unknown quantity at this point
Default Heat/AC Issue
My AC and heat only work an the HIGH setting. Any ideas why and how to fix this??? My baby is a 2000 2DR 2x2 Blazer with manual ac/heat controls......I think.
Old 11-24-2008, 10:47 AM
Default RE: Heat/AC Issue
By heat and A/C, you are really referring to the fan itself, correct?
If that is the case, then the most probable cause is the blower motor resistor block which is located on top of the HVAC housing under the hood.
Old 11-29-2008, 07:50 PM
C5Longhorn is an unknown quantity at this point
I'm having this exact same problem also. The fan does work on level 1 or 2. If I switch it to level 3 or 4 it works. Once I get going, it will then sometimes work on level 1 and 2.
How much is this resistor?
Thanks,
Rick
Old 11-29-2008, 07:59 PM
ACDELCO Part # 1571991 {replaces 15652873 #15094285, 15652873} Blower Motor Resistor $12.05 - RockAuto.com
That part number is good for both the OPs 2000 and your 1999, C5Longhorn, with manual HVAC controls only.
Old 11-29-2008, 09:13 PM
Thanks Swartlkk,
Is it easy to diagnose whether its the relay or resistor? I've heard that if level 1 and 2 don't work it may be the relay. Either way, I'm happy to see that hopefully it won't be too expensive to repair.
Rick
Old 11-30-2008, 02:45 PM
Everything but high is controlled by the resistor. If high works, the relay is good.
Old 12-01-2008, 07:53 AM
Kyle,
You are a wealth of info. Thanks again for the tips.
Old 01-11-2009, 07:27 PM
Is it necessary to put the black cover piece that was cut out back on with black sillicone adhesive.
Old 01-11-2009, 08:05 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
I wouldn't worry about it unless you cut it real clean and want to duct tape it-I usually don't. Jerry
Old 01-11-2009, 08:08 PM
My only concern was water and moisture. If that's not a problem, then I'm not putting it back on.
Rick
Quick Reply: Heat/AC Issue
