Heat/AC Issue
RE: Heat/AC Issue
If you buy an ACDelco unit (and possibly aftermarkets) there will be a seal on the underside to seal. Again, if it makes you feel better, seal it in some additional way. If your resistor had no seal under it you could run a bead of RTV or the like(on the underside) and it should seal it! Jerry
RE: Heat/AC Issue
Thanks Jerry. I bought the Delco unit and it did have the spongy material that seals around the resistor. I may run a bead of rtv just to be safe.
CSCustomCars
11-22-2010 08:24 PM
Lodi Dodi
11-12-2010 06:26 PM
jimhens82
12-17-2009 06:32 AM
