Help major issues
Guest
Posts: n/a
When you changed icm did it come with a small packet of heat sink grease. I seem to remember a ten page thread on a p300 that finally ended with the persons module not coming with the grease. It transfers the heat to the heat sink. This guy tossed every thing but his kids at it and came down to that. Something missing from a box and 3.49 from Radio Shack.
Guest
Posts: n/a
Hey Jon, with changing the distributor you might want to do a read on this.
https://blazerforum.com/forum/tech-a...-timing-24373/
diagnosis before throwing parts..... What brand ignition products did you use ?
have you changed the cap and rotor yet ?
Have you done a leak down test yet ?
P030x - Random/Multiple Cylinder Misfire Detected
Its a common code and it can lead to many things being wrong.
Edit: This shows you the proper way to diagnose the fuel system.
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
