How to remove steering's airbag
Old Jan 6, 2008 | 07:23 PM
fou99's Avatar
fou99 is an unknown quantity at this point
Default How to remove steering's airbag
Hi! while turning on a street corner I heard a noise in the streering wheel of 2001 Jimmy right afterwards airbag light lit and no more power to the radio controls on the steering...I want to know how to remove the airbag so I can replace the broken part.
Old Jan 6, 2008 | 07:34 PM
Default RE: How to remove steering's airbag
Sounds like the clock spring (what keeps electrical contact with all of the electrical components in the steering wheel) has failed.
1. First, disable the SIR system (airbags) Turn the steering wheel so that the vehicle's wheels are pointing straight ahead.
2. Turn the ignition switch to the LOCK position.
3. Remove the key from the ignition switch. IMPORTANT: With the SIR Fuse removed and the ignition switch in the ON position, The AIR BAG warning lamp illuminates. This is normal operation, and does not indicate an SIR system malfunction.
4. Remove the SIR Fuse from the IP fuse block.
5. Remove the left sound insulator, if equipped.
6. Remove the knee bolster.
7. Disconnect the driver yellow 2-way connector located at the base of the steering column.
8. Open the IP compartment door, lift stop and allow door to fully open.
9. Remove the Connector Position Assurance (CPA) from the passenger yellow 2-way connector located behind the glove box.
10. Disconnect the passenger yellow 2-way connector located behind the glove box.
Next, remove the airbag module from the steering wheel:
1. Turn the ignition switch to the ON position in order to unlock the steering wheel.
2. Turn the steering wheel 90 degrees from the straight-ahead position in order to gain access to the access holes behind the steering wheel.
3. Insert a screwdriver into each access hole and push the leaf spring to release the pin that retains the inflator module.
4. Turn the steering wheel 180 degrees in order to gain access to the remaining access holes.
5. Insert a screwdriver into each access holes and push the leaf spring to release the pin that retains the inflator module.
6. Tilt the top of the inflator module rearward to gain access to the SIR wiring.
7. Disconnect the SIR lead wire from the clip on the inflator module.
8. Disconnect the SIR lead wire from the clip on the steering wheel.
9. Disconnect the Connector Position Assurance (CPA) retainer.
10. Disconnect the electrical connector. CAUTION: Refer to Inflator Module Handling Caution in Service Precautions.
11. Remove the inflator module from the vehicle.
After that, you will need to remove the retaining nut on the steering wheel, then use a puller to remove the wheel. The clock spring will be under the steering wheel.
Old Jan 6, 2008 | 07:39 PM
fou99's Avatar
thanks I'll put this at work tomorrow and will come back to you.
How does the airbag come off?
Okay just find the holes you're talking about sorry
Old Jan 6, 2008 | 07:42 PM
fou99's Avatar
Old Jan 6, 2008 | 07:44 PM
fou99's Avatar
See the second set of numbered instructions in my post above.
Old Dec 24, 2008 | 12:35 PM
Agencyman's Avatar
Agencyman is an unknown quantity at this point
Disregard; I started a new thread.
Bruce Hinton
Brian_D
Jul 23, 2011 08:55 PM
marklar
Aug 2, 2010 11:04 PM
Cavalier z24
Sep 3, 2009 08:20 PM
Agencyman
Dec 30, 2008 04:47 PM
Smoked
Jul 25, 2008 07:31 PM
