Ideas
Old 11-06-2011, 05:05 PM
bzoerb's Avatar
bzoerb is on a distinguished road
My thoughts are now that its the spider injector setup I think I'm going to go to the junk yard to see if I can grab one and see if I get lucky before I spend 300+ for a new one.
Thanks
  #22
Old 11-06-2011, 08:59 PM
TheRandom1's Avatar
That's one part I would NOT even consider buying used from a junkyard. I know it's pricey for a new one, but since they're so prone to fail, you're only going to get one that most likely will go bad quickly.
  #23
Old 11-06-2011, 09:22 PM
bzoerb's Avatar
I know I agree, but what I'm thinking is just to try it and see if the problem goes away if it does replace it with a new one. I'm put so much into this thing already.
  #24
Old 11-06-2011, 09:38 PM
TheRandom1's Avatar
I don't believe it's a fuel injector issue. If the injector is leaking, you'd have a drop in pressure when you tested and you don't. If it's clogged, the truck won't run properly. Doesn't seem like that's the issue.
  #25
Old 11-07-2011, 08:58 AM
bzoerb's Avatar
ok other ideas then? I open to anything at this point..
  #26
Old 11-07-2011, 04:26 PM
bzoerb's Avatar
so last night driving home from work CEL comes on again it was off for 450 miles the same dam code came back p0440 I already changed the purge valve and vent valve what the this truck is driving me nuts....
jmatt07
12-18-2009 09:48 AM
bjsx8f
10-26-2009 11:29 AM
a_tack
10-21-2006 03:57 AM
02 Vortech
04-20-2005 12:35 AM
Biohazrd
09-13-2004 10:43 PM
Quick Reply: Ideas
