Need some advice on fixing the truck...
Old 12-18-2010, 03:41 PM
pbrubaker12's Avatar
pbrubaker12 is on a distinguished road
Default Need some advice on fixing the truck...
Ok so I just payed a mechanic hundreds of dollars to replace a fuel pressure regulator, u-joint, ABS sensor, and my stainless steel ABS line that blew in the process...
I still have to replace the Idler arm, the front right hub bearing, the MAF sensor, and an O2 sensor...
Would it save me a lot of money just doing the rest myself or should I just have the shop do it? Are any of these needed replacements especially difficult to do?
Thanks guys
EDIT: Forgot to mention it's an '01 Blazer LT
Old 12-20-2010, 04:49 PM
step66's Avatar
Well,first off it seems that you are paying FULL retail for this mechanic work! Which is is INSANE!-find a better shop! Anyway the idler and the hub should be done by a qualified shop as special tools are needed,and an alignment will need to be done afterwards anyway..with parts at retail-maybe $300 no more! I had the idler & pitman replaced with an alignment for $188! The MAF sensor and the O2 sensor can be done in your own garage for maybe $200 and about 2-3 hours time! Shop around!
Old 12-20-2010, 04:53 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
another thing to do if you have a mechanic do it is buy the parts ahead of time. especially if you know what you need. mechanics mark up parts they put on vehicles. heck i know i do. it will tick off 99% of them but it will save you some money. i would look for a good local mechainic. i would say you go could do everything except the idler arm. i'm pretty sure there is an article for the wheel bearing and the maf sensor is a piece of cake.
84BlazerS10
11-15-2011 07:33 PM
1998 red blazer
02-22-2010 01:59 PM
rcravincase
09-13-2009 07:58 PM
punxweb
09-18-2008 12:19 PM
Quick Reply: Need some advice on fixing the truck...
