testing wires at evap vent solenoid
Tell us what year it is but it's probably normal. On a 2000 a constant 12v+ is supplied to a pink wire and the white is "ground" supplied by the VCM when it wants to open the solenoid. Unless you have a scanner that could command it open you can only check continuity to the white wire in the red VCM connector. (looking at the connector latch down - bottom row, second from the left)
dj00140
03-14-2011 09:51 PM
hilsenteger
03-22-2010 09:18 AM
wdonovan
06-13-2007 11:24 AM
