Swapping a 95 4.3 into a 98 blazer
Old 03-04-2018, 03:37 PM
98 blazzer's Avatar
98 blazzer is on a distinguished road
Default Swapping a 95 4.3 into a 98 blazer
I am swapping a 95 4.3 out of an Astro van into my 98 blazer, I’m noticing some differences such as the oil filter on the 95 is right next to the pan, instead of a remote filter under the radiator. This is my first time pulling and dropping a motor, would like advice and wonder if I should find a different motor?
Old 03-04-2018, 03:58 PM
chevyriders's Avatar
You would need to swap intake manifold, and everything above it from the 98 engine to the 95 astro engine in order to use it. You'd need to use the 98 exhaust manifolds as well.
As far as the remote oil filter goes- you should just have to remove the stud that the oil filter screws onto from the astro engine, and then you should be able to bolt your cooler lines right on.
Old 03-05-2018, 10:17 AM
Snap-Off's Avatar
Snap-Off is on a distinguished road
Need to swap over the oil pan and pick up tube as well , don't ya? And I think the knock sensor is different..Though I may be wrong...
Either way , sounds like fun to me... Good luck man!
Old 03-12-2018, 11:16 AM
Tajohns34's Avatar
I am not sure about Astros, but I though the 95 and the 96+ engines were completely different.
Old 03-13-2018, 01:51 PM
LesMyer's Avatar
LesMyer will become famous soon enough
Enough different to make them not work in the other year vehicle. Oil pan mounting to block is different also, so no switching oil pans from the two engines.
OP really needs a vin W motor (8th digit in S/N) from a S10 or Blazer or Astro van or C/K pickup - 1996-2000. If he is willing to deal with a different knock sensor mounting (using an adapter), he can also use 2001-2005 vin W and Vin X motors - but if you end up with a late motor without EGR, you need to switch your early intake and exhaust manifolds onto the late motor. The 1998 PCM will want to see an EGR valve connected and functional.
You can use 2WD motor in a 4WD and vice versa if you switch oil pans and oil pumps.
Always change the LIM gaskets on these engines unless you are absolutely certain about the ones that are in the engine.
Not a good vehicle for a first time engine pull...... assuming 4WD, its about as difficult as it gets. Needs to get some experienced help or it will never get completed and running again.
rickward
06-24-2015 07:23 PM
Mi99z71
10-07-2013 06:33 PM
siccnezz
03-20-2011 09:33 AM
white95blazer
08-25-2010 08:44 PM
jsjeepie
08-13-2010 08:31 PM
Quick Reply: Swapping a 95 4.3 into a 98 blazer
