water on floor
Old Jul 14, 2011 | 11:27 PM
stlwaco's Avatar
stlwaco is on a distinguished road
Default water on floor
2003 ZR2
I have been getting lots of water on the passenger side floor. Carpet is soaked. Hinge bushings and pins are fine.
I am getting multiple drip points under vehicle when ac is running. So thinking the evap drain is clogged, I crawled under the truck. But I can't seem to find a drain tube. I reached under the evap box under the hood and can't find a drain. But since the evap box is under the hood, can it leak to the inside?
Also I noticed I can smell windshield water from the driver seat (windows up) when I spray the windshield. Where would this be coming in? If this can get in, can rain get in?
Thanks
-Mike
Old Jul 15, 2011 | 12:47 AM
Magman's Avatar
Magman is on a distinguished road
You've got a good sniffer if your smelling winshield wash solution. You sure it isn't radiator fluid you're smelling? Sounds like a leaky heater core to me. Hope it ain't though, that job sucks!
Old Jul 15, 2011 | 07:04 AM
The typical cause of a wet floor on the passenger side is a heater core leak as Magman brought up.
The HVAC drain is located at the lowest point in the HVAC housing on the engine side of the firewall. It is directly above the frame and is very difficult to actually see without pulling off the inner fender. It is possible that a stopped up HVAC drain could cause any condensation to dump inside the truck.
Are all of the cowl vent covers (between the hood & the windshield) in place properly with no damage?
Old Jul 15, 2011 | 10:16 AM
stlwaco's Avatar
The heater core has been bypassed for a couple months now because it leaks. I will try to find the evaporate drain. Cowl looks to be intact without damage.
Old Jul 15, 2011 | 11:28 AM
cdw78's Avatar
cdw78 is on a distinguished road
Is it possible maybe the doors arent sealing good or even the windshield ?
Just a thought.....
Old Jul 15, 2011 | 11:47 AM
stlwaco's Avatar
I thought that too. I just ran the hose all over that corner of the truck for about an hour. Nothing getting in.
For the evap, I stuck my hand under the box while ac was running. Water is coming thru all along the bottom seam.
Old Jul 15, 2011 | 11:50 AM
Sounds like a stopped up drain then. There is one spot it should come out of, that I am sure of. If you have to, pull the passenger side inner fender. It isn't that difficult to do. Basically unbolt the PCM & radiator overflow bottle, pop out any wire retaining clips, then unbolt it.
Old Jul 15, 2011 | 01:09 PM
stlwaco's Avatar
ok. i will have to do that tomorrow then. It has got too hot for anymore work today.
EDIT: I found this post of yours - https://blazerforum.com/forum/2nd-ge...eres-fix-1091/
if I were to flip the recirc door open, would it be wet in there if the drain is clogged?
Old Jul 15, 2011 | 01:50 PM
That door is up higher on the HVAC housing than the drain and it is on the cabin side of things. The A/C core is on the engine side of the firewall. It wouldn't hurt to take a look there though.
toaks1
May 13, 2011 10:22 PM
contour1
Jan 3, 2011 04:36 AM
chas317
May 4, 2010 11:14 PM
banshee386
Apr 5, 2010 10:57 PM
jon66
Feb 16, 2008 07:04 AM
