water on floor
Old May 4, 2010 | 07:03 AM
chas317's Avatar
chas317 is on a distinguished road
Default water on floor
Last rain storm ,found rain water at base of floor on passeneger side of floor,also days later,washed truck and found water at base of pass, side floor again. Removed cowl screening and tried to hose out any leaves or debris. Flooding still occurres.Any solutions. Thanks Charlie
Old May 4, 2010 | 08:32 AM
Benedict1337's Avatar
sounds like your weather stripping is messed up somewhere
Old May 4, 2010 | 08:54 AM
*moved to a new thread* - Please do not post off topic questions in other threads. This had nothing to do with the 3 questions.. PCM, Rims and Led interior thread you posted it in. Also, please provide some information about your vehicle whenever you request technical help.
With that said, have you cleaned the HVAC drain located at the lowest portion of the HVAC housing as seen from the firewall? It is located directly above the passenger side frame rail where the HVAC housing and firewall meet. At least it is there on the 2nd gens. You haven't provided your vehicle information...
Old May 4, 2010 | 02:03 PM
chas317's Avatar
Default leak in cowl vent
No ,it's coming through fire wall, never leaked before, beleive water is coming over vent opening for outside air into car. Thanks Charlie
Old May 4, 2010 | 02:43 PM
Were you replying to someone other than yourself? If so, who?
Old May 4, 2010 | 11:14 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Check your pass side door pins and bushings. The upper bushing on my driver's side was cracked and was causing the same problem.
stlwaco
Jul 15, 2011 01:50 PM
toaks1
May 13, 2011 10:22 PM
contour1
Jan 3, 2011 04:36 AM
banshee386
Apr 5, 2010 10:57 PM
jon66
Feb 16, 2008 07:04 AM
