[brakes] Electrical clicking sound when pedal is pressed (normal?)
Old Jul 13, 2009 | 11:07 AM
GloryImSaved's Avatar
GloryImSaved is on a distinguished road
Default [brakes] Electrical clicking sound when pedal is pressed (normal?)
I've just noticed a clicking noise whenever the brake is pressed. It is the same sound one might expect from a turn signal flashing (from the flasher). I'm assuming it's the switch for the brake lights but I don't remember it being so loud.
I've had this Blazer for a week but I haven't driven it more then 50 miles. Expect many posts.
Old Jul 13, 2009 | 02:03 PM
Yooper's Avatar
Yooper is an unknown quantity at this point
What year is your Blazer? All newer vehicles are equipped with a safety device that prevents you from shifting out of 'park' without pressing your brake. The noise you are hearing is more than likely just this device disengaging thus allowing you to shift out of 'park'.
Old Jul 14, 2009 | 06:27 PM
I have a '99 Blazer LS.
The clicking went away after I drove it a bit. But, as I mentioned, the sound is very similar to the turn signal and is coming from the same direction when ever I press / depress the brake (well, was...). I love how it's making me out to be a liar. Cars... you know?
Old Jul 14, 2009 | 08:19 PM
Yooper's Avatar
If it is what I mentioned it wouldn't be clicking while you are braking under normal driving conditions. If it only clicks when you press the brake to get out of park than your problem is solved. If it DOES click under normal driving conditions I am not sure what to tell you. . . Sorry.
Old Jul 16, 2009 | 12:25 AM
Clicks in park...
Old Jul 16, 2009 | 12:39 AM
1995 Blazer's Avatar
1995 Blazer is on a distinguished road
your problem most likely is that the multi function switch witch includes cruise wipers turn signals and i belive the 4 ways are one switch what happens is over the years the metal contacts wear out and mix with the dielectric greese inside the switch and complete the circut but only allows enough current to pass to click the blinker relay and the brake lights are ran through the same wire ie were the current clicking the relay is coming from and also belive its $150 for the part
if the click is random and does it sometimes and others it wont or has crazy spaz attaks thats your problem i my dad has a 2000 with the same problem and i also have a friend with a 98 with the same problem
good luck
Old Jul 16, 2009 | 12:47 AM
Yooper's Avatar
Originally Posted by GloryImSaved
Clicks in park...
If it only clicks in park than you have nothing to worry about. It is a safety mechanism that prevents you from shifting out of park without the brake being applied.
Old Jul 16, 2009 | 12:50 AM
o my bad i thought you said it was happening when you were driving otherwise yea
i dont have to worry in 95 they dident care about safety i can shift without my foot on the brake
_HeC_
Feb 10, 2013 04:43 PM
Dieseldog95
Nov 10, 2010 07:10 PM
rastoma
Mar 4, 2010 08:34 AM
Donnie3543
Aug 13, 2009 12:38 PM
apekim
Sep 15, 2007 10:46 AM
