Engine sputters when pedal is pressed
Old Aug 12, 2009 | 04:29 PM
Donnie3543's Avatar
Donnie3543 is on a distinguished road
Default Engine sputters when pedal is pressed
Hello, new to the site, I recently purchased a '97 Blazer with the 4.3L Vortec, it ran great for a week but today it was really running weird, it has a slight miss when at an idle, it accelerates ok but when I step on the peddle to get into it the engine sputters and it sounds like it wants to stall. I don't have any engine codes.
A quick note, it has 7 gallons of fuel in it that was left out in a can that was left in the rain so there may be water in the fuel, I'm not sure what the symptoms of that would be though. Any help would be great, thanks!
Old Aug 12, 2009 | 05:10 PM
CraigSnedeker's Avatar
we have the same exact thing! a hesitation.
Old Aug 12, 2009 | 05:31 PM
Donnie3543's Avatar
Something is deff. wrong, the truck almost stalls unless I drive it like grandma
Old Aug 12, 2009 | 06:07 PM
rafa.jrbarajas's Avatar
rafa.jrbarajas is on a distinguished road
that happened to me and all i did was changed the idle controll sensor and the idle control valve and that fixed the problem
Old Aug 12, 2009 | 06:19 PM
Donnie3543's Avatar
Is there a way to test it? Autozone wants $65 for a new one.
Old Aug 12, 2009 | 07:40 PM
how do you even do that?
Old Aug 13, 2009 | 01:24 AM
xCHIPx's Avatar
xCHIPx is on a distinguished road
I have a 99 and I had the same problem for awhile when I would first start it, It would start missing and usally dies unless I gave it some gas. But I just put new plugs in it and it runs almost perfect now. But sometimes when I first start it and try to drive the motor will sputter and then kinda bogs down. But if I let off the gas and try again it gos. But most people have told me its an injecter problem.
Also If the gas you have in it is old and has been out in the rain that could be your problem.
Old Aug 13, 2009 | 12:38 PM
Donnie3543's Avatar
Well, I'm gonna assume for now that it is crappy gas, it has not acted up at all and I have about 50 miles on it since last night. Thanks for the responses!
_HeC_
Feb 10, 2013 04:43 PM
Dieseldog95
Nov 10, 2010 07:10 PM
redblazerlt
Aug 18, 2009 10:41 PM
GloryImSaved
Jul 16, 2009 12:50 AM
RedOctober
Oct 10, 2006 02:06 AM
