[VIDEO] Really weird sound coming from front end...
Old Dec 20, 2016 | 02:04 PM
manthraper's Avatar
manthraper is on a distinguished road
Default [VIDEO] Really weird sound coming from front end...
Hey guys, I've got a 2000 blazer 4.3l. Weird sound coming from front end I have no idea what it is. I've replaced the ujoints, they're good, I've checked the wheel bearings and there's no play. Transmission oil is good, tires were just balanced (just got winter tires put on)
The sound starts around 40kmh, and gets worse the faster I go. It is not dependent on RPMs it is affected by my speed only. It makes a 'whining" sound while I'm getting up to speed and turns into a grinding. When I brake it sounds like a low moaning.
My next thought is maybe warped rotors..?
Does anybody have any experience or thoughts on this?
Thank you
https://www.youtube.com/watch?v=LROB...ature=youtu.be
Old Dec 20, 2016 | 06:00 PM
TrailBlazer's Avatar
TrailBlazer is an unknown quantity at this point
When did the ABS light start coming on? I'm guessing front hub because of the ABS light.
I've had a hub start going out, sounded like a jet was flying over the truck but still had no play when the tire off the ground with ABS light on.
Most (all but one) of the hub issues I've had over the years, the ABS light is always the first indication.
Old Dec 20, 2016 | 09:10 PM
manthraper's Avatar
Thanks for the reply
ABS light has been on for quite a while now, unplugged the fuse because ABS was terrible in the snow.
I did check the wheel bearings, checked top and bottom no play at all really. How else could I diagnose the hubs before replacing them?
Any other ideas? Me and my buddies are baffled :/
Old Dec 21, 2016 | 05:26 PM
manthraper's Avatar
found out it was the rear diff, if anybody was wondering
Old Dec 21, 2016 | 07:21 PM
Strangerock's Avatar
Strangerock is on a distinguished road
Was it a bearing ?....if so do you know what bearing it was ?
Old Dec 21, 2016 | 07:28 PM
rockp2's Avatar
I was wondering. Thanks.
AGodlyCanuck
Jul 5, 2014 08:29 AM
hanksta2
Jan 25, 2013 03:57 PM
PhilX
Oct 21, 2010 08:55 PM
johnroe2727
Dec 6, 2009 05:45 PM
martamay
Jan 18, 2008 05:27 PM
