Weird Engine issue. With VIDEO! (You love video!)
Old Jan 11, 2013 | 06:22 PM
hanksta2's Avatar
hanksta2 is on a distinguished road
Question Weird Engine issue. With VIDEO! (You love video!)
So my 2000 s10 Blazer has been doing this for a few months now. Everything else seems normal.
While accelerating, the RPMs seem to be fluctuating like crazy...like smoker trying to run a marathon. See the video for better explanation:
2013 01 10 18 58 05 691 - YouTube
Not sure what is causing this...
Old Jan 11, 2013 | 06:55 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
I have no help but a comment,very strange.
Old Jan 11, 2013 | 06:56 PM
hanksta2's Avatar
Strange indeed. No smoking, no sound, everything else seems to be functioning great (other than the noticeable loss of power I've experienced over a decade of driving this thing).
Old Jan 11, 2013 | 07:51 PM
The only thing that I can possible think off is that the torque converter came out of lockup mode casing the lack of power and fluctation in rpms like that.
Old Jan 11, 2013 | 08:44 PM
rexazz2's Avatar
check transmission fluid level ,burnt smell ??
Old Jan 11, 2013 | 08:58 PM
CAB's Avatar
CAB
CAB is on a distinguished road
Since you say that "Everything else seems normal", I am going to say that the tach movement is not engine related and is most likely an electrical issue or the tach itself. That much rpm fluctuation would be felt, especially while accelerating.
Old Jan 11, 2013 | 09:19 PM
hanksta2's Avatar
My apologies for not being more clear--it's definitely an RPM fluctuation, because I can feel it, too. Outside of THAT, everything seems normal.
My thought was to take it to a tranny specialist and get it checked out.
Old Jan 11, 2013 | 09:37 PM
CAB's Avatar
CAB
Ok that helps. A bad torque converter will act in just this way. Apply just enough brake pedal pressure to apply the brake lights. That should disengage the tcc. When doing this and if the fluctuation does not go away, then it is not tcc related. If it does stop and comes back with your foot off the pedal, then the tcc is the issue.
Old Jan 12, 2013 | 12:13 AM
hanksta2's Avatar
Well the fluctuation will go away the instant I let off the gas. Are you saying I should tap the break while still applying the gas pedal?
Old Jan 12, 2013 | 06:12 AM
CAB's Avatar
CAB
Barely ride the brake(just enough to turn the brake lights on) while accelerating at the speed the rpms are varying.
